Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: How to get towing most economically
  1. #41
    Anaheim
    566
    Ray, Thanks for the plug, I can't take the credit for that idea. I think if you look back Jon or someone else came up with the separate light bulb deal.
    Kevin
  2. #42
    Orren Zook Guest
    Quote Originally Posted by Ray Davis
    I think I will try to do what Kevin suggested, and that is embeded the lightbulbs somewhere in my current light socket area. In that way I don't have to re-wire for the braking system (which wants a relay inline if I'm wiring direct to the real lights)
    Someone makes a wiring kit that you can buy that contains the stop/tail light sockets - you drill holes in the back side of your toad light housing and plug the socked into the hole, run the wires to your bus cable.... a very easy simple installation. I'll get the name of supplier for you in the morning.
  3. #43
    Alexandria
    2,161
    Whoa satellite boy,
    I just got defend the magnetic lights (with a tip of the hat to BOB-00). I've put 18,000 miles with them on the Toaster w/ no scratching. However, I run them thru the engine compartment, directly out to the drivers door, inside the cab and out the sunroof in the back. No problemo.
    MM
  4. #44
    Landrum, SC
    799
    Quote Originally Posted by MangoMike
    Whoa satellite boy,
    MM
    Mango, have you been to the farm recently? I see you used the word "Whoa" with the satellite boy?
    We have towed two PT Cruisers(one at a time of course) with our previous coaches and the with our present coach and the last one. We have never had a scratch issue using the magnetic lights. However, we do run the light wiring through the engine compartment, inside the car/SUV, and out through the back of the windows or hatch. Very little wire is exposed and we have never had an issue. Sorry to hear that you had a problem with yours!
    Debi and BOB-00 who tips his go-kart hat back to you Mike
    2000 Vantare XL, 2005 Jeep Cherokee
    Landrum, SC
  5. #45
    Wiring kit by Blue Ox, you can get it through camping world or Blue Ox direct.
  6. #46
    Now, now. No offense intended, I'm just relaying my results. I did after day-one route the wires through engine into the car. But where I had issues was in two places:
    1. Coming out the back door, looping around onto the trunk where the lights were. There's an 8 inch section that I tried everything including duct tape to keep it from flapping.
    2. Between the two lights (they were joined together by 2 foot section of wire), I tried folding this down under the trunk lid, but they still flapped somewhat.
    Admittedly I may have had better results if I were able to route the wires from the backseat straight through into the trunk and up. But given the rush I was in to get going, I wasn't able to try that. The darn hybrid has the batteries hidden back there somewhere, and I wasn't able to pull up the back seat to get the connector through there. That would have helped a lot.
    I'm sure that cars with a back hatch, instead of a 4-door like mine would have worked better. A lot less exposed wire.
    I'm hopeful that it will all buff out anyway. The car is so darn dirty from towing, it's hard to tell!
  7. #47
    ken&ellen Guest
    Default Magnet lights = extra safety
    I am with Mango....no scratches on our Jeep Liberty and those lights are mounted high for better visibility. Plus when my Brake Buddy kicks in I have double the light output. At night I can see them in the back up camera....very bright! If only they were LED's? Ken
  1. Towing connecter
    Last Post: 08-04-2009, 08:39 PM
  2. towing 07 gmc yukon xl 3/4 ton 4x4
    By chtree in forum TOADS, TRAILERS & TOYS
    Last Post: 02-06-2009, 11:27 PM
  3. Towing 4-Down without damage
    By Joe Cannarozzi in forum TOADS, TRAILERS & TOYS
    Last Post: 06-02-2008, 10:43 AM
  4. Towing '06 Colorado
    By BrianE in forum TOADS, TRAILERS & TOYS
    Last Post: 05-06-2006, 10:56 PM
  5. Not Towing
    By Jon Wehrenberg in forum RALLIES AND GET-TOGETHERS
    Last Post: 04-14-2006, 04:47 PM
