Results 1 to 10 of 12
Thread: Anyone looking for a project??
    Menifee California
    994
    Default Anyone looking for a project??
    Here is a project for you "do it yourselfers"
    http://mohave.craigslist.org/rvs/1435295827.html
    Feb 2006
    Bristol, Tn
    1,647
    Default Go For it
    Looks like a good low mile, locally owned, no salvage yet history unit, nothing wrong with it that money won't fix.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Yep, now that there's a PROJECT!!
    Pinehurst
    952
    That looks like a lucky 7
    Aug 2007
    Grass Valley
    480
    Gents: When you think MCI always keep a slopping floor in mind. Some if not all have a floor that slopes back to front. To flatten it for conversion use the whole floor must be removed thus requireing a major ground up bus re-build.
    Harry
    Default Tools for the Do it Your-Selfer Bus Remodeler
    Maybe Mango, Jon and JDUB could explain the correct usage of the following at the next POG Rally. Enjoy!
    Men's Tools Explained by Richard Barnes
    DRILL PRESS:
    A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
    WIRE WHEEL:
    Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, shit!"
    SKILL SAW:
    A portable cutting tool used to make studs too short.
    PLIERS:
    Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
    BELT SANDER:
    An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
    HACKSAW:
    One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS:
    Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETYLENE TORCH:
    Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
    TABLE SAW:
    A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
    HYDRAULIC FLOOR JACK:
    Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
    BAND SAW:
    A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
    ENGINE HOIST:
    A tool for testing the maximum tensile strength of everything you forgot to disconnect.
    PHILLIPS SCREWDRIVER:
    Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
    STRAIGHT SCREWDRIVER:
    A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
    PRY BAR:
    A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER:
    A tool used to make hoses too short.
    HAMMER:
    Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
    UTILITY KNIFE:
    Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
    Son of a bitch TOOL: From my wife Audrey - "God love her"
    Any handy tool that you grab and throw across the garage while yelling, "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
    Richard and Audrey Barnes
    and Jessie Jane The Wonder Dog!
    1998 Liberty
    2008 Saturn VUE
    My Blood Runs Deep Orange
    We don't actually use the tools we buy. They are for show only.
    Any tool with a motor: likely to be used once or twice and then wisely stored away for posterity.
    parksincpp Guest
    Mr. Barnes- LMAO
    Cyndie
    Menifee California
    994
    Default Crap!
    Sounds like my shop!!
  1. Project of the day- steering rod boot
    By Petervs in forum Busted Knuckles and Greasy Jeans
    Last Post: 05-21-2010, 02:22 PM
  2. AC Upgrade Project
    By Will Garner in forum Country Coach
    Last Post: 12-25-2009, 03:17 PM
  3. Here's a Project for Ya
    By Ben in forum Ah, Nice Coach...
    Last Post: 02-22-2007, 11:01 AM
  4. Great Project
    Last Post: 08-13-2006, 09:18 PM
