To all,
I am writing this at the request of Jim Skiff and the campground.
There are issues here concerning parking that are not apparent when looking at the campground map.
1. The office is at the lowest point, the east side of the park rises up at a fairly step rate. The west side is a little less steep.
2. The section on the map marked E30 thru E37 is still under construction and should be done in time for the rally, weather permitting.
3. There are sites here that look like they would be big enough for a bus but due to the steep approach angle, a bus will not fit.
4. The office here is making an effort to put everyone close to the people they want to be next to, but due to some sites not being able to hold a bus, they can not get everyone excately where they might want to be.
A NOTE of CAUTION:
Some sites like the one I am in, E10, look like a pull thru on the map. It is a pull in, back out due to the VERY steep angle on the front third of the pad. I had to raise the rear of the bus as high as I could and drop the nose to get into the site with out dragging my tail.
So when you look at your site before you park think about raising up on your bags as high as you can. Now don't get all crazy on me about this, it is not as bad as it sounds and will only apply in a few cases.
I will post a few pictures latter today to give an idea of what things look like.
It is a nice place and I a sure everyone will like it here. Let the party begin.
