Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: BUS HUBCAPS
    Default BUS HUBCAPS
    I have the original hubcaps that came with my bus. They are polished SS buckets, held on by a central spinner nut. The inner edge of the bucket is protected by a silicone rubber channel that also protects the aluminum rim and seals the whole assembly from the weather.
    I do not know the name or manufacturer of the caps. (need it to contact them)
    I need 29" of the channel as my bus came with a substitute POS that does not stay put at assembly.
    Can anyone help me with the brand name of the hubcaps or a source for the silicone rubber channel?
    Jeff Bayley Guest
    Jim-
    I need one also. I tracked it down once before but can't find where I bought it. I think the ones on the drive axels are called Top Hats (maybe ?). I need the one that goes on the tag and also the fronts. It has a spinner and the thread that holds the spinner on is reversed. I don't want to show up in OKC looking getto.
    Maybe one of us can take a photo of one of the other ones and post it to make sure we get the right one.
    May 2006
    546
    Default Try Here
    Jim,
    I was in need back in 2007. I had an encounter with a traffic attenuator at the West Virginia Turnpike Toll Booths. ALWAYS use their far outside (right) lane, it is bigger than all the rest.
    Anyway, you might try contacting:
    RealWheels Corporation
    www.realwheels.com
    3940 Tannahill Drive
    Gurnee, IL 60031
    (800) 982-1180
    My sales contact was very accomodating. His name is Bjorn Cannon, bcannon@realwheels.com
    I don't know if he is still there or not but it is worth a toll free call to find out. The rubber channel is still working for me.
    I also got a new piece for the tag axle hub covers from Parliament when I was in Florida. I ran into Truk while at Parliament but that is another story.
    3,782
    Jim,
    I have different covers, but mine also have a strip protecting the rim from the cap. While at Liberty last January, they sent me to an Auto Body Shop Supplier and they had what I needed in a plastic chrome color. I bought an entire roll for about 8 bucks. See me at OKC and it may work for you as well.
    Found just the right thing and a little more.
    http://www.aircraftspruce.com/menus/...erchannel.html
    http://www.aircraftspruce.com/catalo...s/uchannel.php
    Of all places who would have thought they would have it.
    Good info, Jim.
    Thanks for posting....
    Jeff Bayley Guest
    I actually need the whole hub cab but I need to post a photo since there are different styles. Will post it later. Didn't realize Jim only needed the rubber.
    Sugar Land, TX
    1,307
    Quote Originally Posted by Will Garner View Post
    How much damage was done ?
    Gary S.
    Apr 2008
    no where
    439
    This is an old thread, but I could not find an answer to a couple of questions that I feel I should already know the answer to.
    1. Are our rims hub or stud piloted ?
    2. What size are our lugs nuts? So I can buy the right size lug nut covers...
    Seems like I should already know this, makes me feel bad, but I figure others need to now also.
    Orren Zook Guest
    Quote Originally Posted by ajducote View Post
    My 1999 chassis uses stud piloted rims and the outer Budd nuts measure 1 1/2" across.
  1. Moon hubcaps
    By Kenj in forum Country Coach
    Last Post: 02-25-2010, 01:12 AM
