I've beem emailing the people at Silverleaf.
Silverleaf say's they have a rep in the area at the time of the OKC rally and can come by. I'm trying to get them talking to Jim Skiff who I presume would be neccessary to bless their doing a talk. Maybe more so if he thinks the group wants it. I think they would have products on hand to sell and they say they can spend some time doing the basic set up and maybe they can show other owners of it a few new tricks. Out of fairness to the rep and also members time, I guess we could get an idea of what the interest is for people buying any of their products. Maybe a memeber that owns the Silverleaf can do just as good a job but the rep is supposedly not going far out out of his way. I'd like to get my stuff ahead of time if their's no demand and fiddle around with installing and playing with it at the rally.
http://www.silverleafelectronics.com The VMSPC is the lap top version.
I think at least a half dozen POG'ers have it and everyone seems to love it. For those that missed some of the comments here's just a few but you can find more by searching for "Silverleaf" on the search function. http://forum.prevostownersgroup.com/...ght=silverleaf
I'm going to get this whether they come to the rally or not. It's only $400 including the hardware adapter and the software instead of $1,200 for a new Pro Driver. 1/3 the price, 3 times better. I'm posting this for other Silverleaf owners to find out how many are coming to OKC and also to get suggestions on which spare monitor to get since the Pro Driver can come right out of the dash and a jig saw or dremel or the like can be used to make the opening larger to accommodate a 7" monitor. I think there's enough room but still need to measure. I saw a spare monitor on Silverleaf's sites that one of the members here pointed out ( http://www.silverleafelectronics.com/?q=node/84 ) where the owner mounted a 7" monitor on the top left of his dash which was ok but why not stick it where the Pro Driver goes since that is junk (mine anyhow). He must use the array option on the computer. ??? Some people just use a split screen on the lap top and size the windows to see both. Would appreciate opinions from other owners here of how the Pro's and Con's of different set ups. Three's a forum on Silverleaf's site where I'll probably post a copy of this also but not sure how active that forum is.
Here's an excerpt from my response to the Silverleaf rep. See ? Just an excerpt. Shortening posts still needs work I know. If only I could break one hand........wait, bad suggestion. Might provoke a freak accident at OKC.
Jim- After reading your email I decided it's best not to attempt a dedicated computer. But if you don't hook the computer each time, presume it will muck up your data or does the $400 brain continue to keep tabs ?
I'll have the extra space from the Pro Driver available for a bout a 7" monitor. There's room to remove the panel it mounts to and open the hold a bit more if necessary. Using an array set up for two monitors it should should let you put what ever window (program) you want on the small screen and resize it to fit whether that is the GPS software or the Silverleaf monitor. It's been a while since I used two monitors on one computer which was a tower/home computer and can't remember if it required an accessory to use it. I don't think it did.
