Adam,
No it won't safely get you on top of the bus. Just reaches the top when fully extended, so you could probably get up there but not very safe. I have an extension ladder in the barn for that.
Back in the olden days when I used to raise the Braun antenna I needed to get on the roof to lower it when it decided it did not want to go down. Now I cannot envision any need to get on the roof.
I have a fold up ladder that will open to a height that will get me on the roof if need be. The reason why a tall ladder is somewhat important is to be able to wipe the sides of the coach from the top down. Other than having the ability to reach the top I see no need to get on the top, but you must be able to reach that high because on more than one occasion I had to deal with awning issues.
Adam, it is my opinion that with your at times tight schedule that it would be good to be able to get up on the roof whenever you wished. Ken Z, roof air cover blowing off and Dale F vent problems needed roof access.
Every coach with awnings is a potential candidate for an awning issue.
In both my cases it was wind that was sudden, unexpected and violent. In both cases I had to get up so I could secure the awning to the coach. In both cases something failed and I ended up using wire coat hangars to mechanically secure the awning such that I could drive.
Having a good ladder that did not force me to work off balance or reach excessively was very important because the wind was extreme, and I needed to make the necessary repairs RIGHT NOW. I hope I never experience the problems we had, and I am now overly cautious with the awnings having the normal locks, the hook type locks, and velcro straps, but it we again get a failure at least my ladder is tall enough to get me up there to do the repairs.
I would leave a lot of stuff behind if I needed the room, but I would never leave a substantial tall ladder behind. And I say that having zero intention of getting on my roof.
BTW I have a Little Giant ladder that will become an almost 18 foot step ladder exclusively for home use. I think they are a substantial ladder and an excellent one, but even a six foot one might be too big for a coach. I have a four section folding ladder that I have had for almost 20 years and it has done very well and takes up minimal room relative to its open size.
My previous bus had a Little Giant ladder, which worked fine, but as mentioned you couldn't get on top of the coach. You can IF you bring up a park bench, however.
In my new coach, I purchased a ladder from http://www.xtendandclimb.com/
I got the 15.5 footer, which makes it trivial to get on top of the coach. There are cheaper knock-offs on this ladder on Ebay, but I don't know if they are as strong or safe.
I used mine this weekend to get on the coach roof. The nice part it is much more compact than the Little Giant, however there are things that a ladder like this cannot do, that an a-frame can.
Hey POGgers,
I have a ladder called a "Bean Stalk". It's a 3 part ladder that easily gets me up to the top of the bus. There is also an accessory that makes it into a step ladder for working on the sides/windshield of the bus. Not the greatest for storage, but works great for getting on top!!
Making our way (round about) to OKC,
Ken
Here is a muti use ladder I purcased. It stores at a length of 4 feet., It is a ladder, extension ladder, & stairs.
http://www.walmart.com/catalog/produ...uct_id=8198588
One thing , with a slide Coach , you don't need a real long ex. ladder, as you can step onto the top of a slide to get to the roof.
Unfortunately I have no choice in getting on the roof. My clearcoat is coming off and along with it, some of the caulking and sealant on the roof penetrations.
Have a Werner M1 multipurpose ladder in the barn which is either an 8' A frame or 16' extension. Rated at 300 lbs so I have plenty of room to grow. Also makes into a 5' tall platform which is nice. It is actually compact enough to carry on the bus, but the little giant should suffice.
