Results 1 to 10 of 16
Thread: Rear Bumper removal and cleanup
    Apr 2008
    no where
    439
    Default Rear Bumper removal and cleanup
    A while back I decded to tackle some rust and ugly area's in the rear of the bus. I suspect the previous owners had run on salted winter roads and never rinsed the salt off. So I had (and still have a few) areas that looked real bad.
    Attachment 5173
    Rear Bumper and ugly mud flap removed
    Attachment 5174
    Hitch removed
    Attachment 5175
    cleaned and primed
    Attachment 5176
    painted gey
    Attachment 5177
    hitch cleaned, painted and reattached
    Apr 2008
    no where
    439
    More photos
    Attachment 5180
    Close up of had bad it was
    Attachment 5181
    another one
    Attachment 5179
    I polished the rear bumper before I put it back on
    dalej Guest
    It looks like you did a really good job Andre! It just feels good doesn't it.
    What paint did you choose to match that frame? Looks really really nice.
    Feb 2006
    Bristol, Tn
    1,647
    Andre: Great Job. Looks A1. And I know that you feel great about getting her done.
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
    Great job Andre. How many hours overall did you spend on the project. Did you sand blast the hitch? What type of paints did you use for re painting?
    Wilsonville, OR 97070
    852
    Andre in the second post first picture what material is that white pipe made out of?
    GregM
    That is painted copper fittings, all sweated togeather Greg.
    Brian found that out when he removed all his radiator plumbing on his Liberty to have it powdercoated, and couldn't.
    Looks nice hu
    Apr 2008
    no where
    439
    I sent most of 1 weekend on this job. I do not have a sandblaster so I used steel wire brushes of various sizes and shapes on an electric drill and some sandpaper to clean out and remove as much rust, paint and dirt as possible.
    For paint I went to Lowe's, it is close by and had a large selection of Rust-Oleum.
    4 Step Process.
    Grind away as much rust and dirt as possible, and wipe down with paint thinner.
    Paint 2 coats of Rust-Oleum "Rust Reformer" that is the black paint in the pictures
    Paint 2 coats of Rust-Oleum "Grey PRIMER"
    Then 2 coats of Rust-Oleum "All surface Gloss Slate Gray"
    The gray is close to the Prevost Gray, but there is an area where you can see the line between old and new. But it looks a hundred times better then when I started, so I called it a success.
    Believe me it is not a perfect job, but I am happy with the results.
    Hope I answered everyone's questions.
    Battle Ground, WA
    851
    Since Joe brought it up......When refurbishing the 8V in Tom's coach, I thought the large water-pipes would look good powder-coated. Bad idea. The baking process melted the soldered joints in the pipes. Strip, prime and repaint is the right way to go on those puppies. There are no secrets in this bunch.
    Great job Andre, worries me a little about what's behind our bumper though.
  1. Bumper Storage Compartment Question
    By Jeff Bayley in forum Ah, Nice Coach...
    Last Post: 10-12-2024, 04:24 PM
  2. 60 series Fan removal
    By ajducote in forum Engines, transmissions, axles and wheels
    Last Post: 08-02-2009, 02:09 PM
  3. Rear bumper removal
    By jelmore in forum Busted Knuckles and Greasy Jeans
    Last Post: 04-12-2009, 11:54 AM
  4. Rubber Bumper Issues
    Last Post: 06-01-2007, 02:30 PM
  5. Front bumper, lights
    By bwalz in forum WANT/NEED PARTS?
    Last Post: 04-25-2007, 09:26 AM
