Results 1 to 10 of 29
Thread: Want To See A Naked Bus?
Threaded View
  1. #12
    Don't you feel better you got that off your chest.
    If you only had another inch
    I bet you won't do that again
    Someone should come up with something like the back-up alarms that are currently available on some cars, modify them to work on the sides of our buses down low, have it manually operated with a switch, modern high tech curb feelers.
    I saw where prevo now has factory tire monitoring systems for motor home shells.
    Keep us up on the progress. I went 6 months without ours at home, suck it up, get ahold of yourself, we will help you thru it.
