Originally Posted by
Roadrunner
OTR air is a system that has a separate compressor that runs off the engine. It is in addition to the dash air on some coaches. Prevost OTR air is the best and most expensive. Country Coach installs a significantly cheaper system that does a good job if working properly. It does not have the output that the Prevost OTR air has. OTR air allows you to cool the bus while traveling without running the generator.
