Results 1 to 10 of 17
Thread: Oh Oh...
    Mar 2009
    Harrison
    623
    Default Oh Oh...
    Getting ready for our trip to Colorado, changed fuel filters, checked oil and tranny fluids by the Prevost book. noticed a lot of grease around shield for radiator fan belt pully, cleaned it up and shot some more grease into fitting and also the belt cylinder but noticed that the main "big" belt for the radiator looked a little "loose" while running engine to leak check fuel filters. I can actuall grab the gearbox assy at the pulley (of course after shutting off eng/batteries) and give it a pull/shake and the whole assy jiggles. Is this right? I don't remember doing it before. I did not have the engine running long enough to really build up any heat. With the engine running should not the belts be turning a nice smooth rythm?
    The 8V's are a little more jerky and loose compared to the series 60, but they're designed to move around a little. Did you check the belt tension to see if it feels OK? You should have an adjustment arm for the belt tension and making the arm longer tightens the belt. Do you have the updated fiberglass fan? The metal fans were prone to fail.
    If you had a lot of grease coming out of the pulley behind the cover, you could have a seal/bearing issue.
    Oct 2007
    104
    rahangman.......Inside the rear engine doors, on the rear panel near the oil fill, you will find a valve with a shut-off handle and a air check valve. This valve should have 50-60lbs psi. Start the engine, let the coach air pressures max out, then check the air pressure valve. The belt should be tight.
    Oct 2007
    104
    RAHANGMAN.........Use your tire gage to check the air pressure on the air chuck to the left side of the air regulator.
    Mar 2009
    Los Angeles
    65
    Default belt tensioner
    My '90 country coach does not have an air tensioner, which is what the last two posts were talking about. If yours is like mine, air pressure (or lack) is not related to your issue. If yours is manual, you will have large turnbuckle type device to tighten the belts. They should be tight. I had to experiment a bit to figure out which way makes it tighter.
    p.s.: I know I promised to scan the CC manual for you, but I keep forgetting to bring it home with me. Sorry about that. Will try to remember again this weekend.
    Mar 2009
    Harrison
    623
    How can I check this seal/bearing issue? I will try to determine where the grease is actually coming from either the front of the pulley or behind (engine side of pulley) If it is determined that I have a bearing issue, how do I go about replacing it?
    Battle Ground, WA
    851
    It's easy to over-grease the pulley block. When you do the pulley shaft throws grease for a long time. Would suggest letting it dry itself up and then checking the pulley for excessive heat when you shut down for lunch and at the end of the day. That pulley block is really pretty durable. My normal lube was 1/2 a pump with a grease gun every 5k miles or so.
    Just about everyone over greases that point. A real PITA trying to keep things clean around there.
    Use high temp or marine grease it is recommended for that anyway and it will stay put better.
    I put 1 pump in it every trip. Still makes a mess but small.
    Battle Ground, WA
    851
    Here's hoping you can make a mess in the near future, Joe.
    Mar 2009
    Harrison
    623
    Wink Thank you one and all
    Cleaned up the mess, as Jon says, so you can see where/what your problem is, and charged up the air system good and checked the air pressure from the schrader valve next to the belt tensioner control valve , a little over #60. Shut all down and decided , heck, got the grease gun out, and the belt tensioner cylinder rod ends looked like I could grease them, but, lucky me, broke one of the zerks. These things are tiny ! went to 3 different locations (Saturday in Arkansas ) and couldn't find any small enough. Rod ends looked ok, cycled the cylinders once and everything moved smoothly, so will hunt some replacement zerks down while in Denver. Thanx again everyone, I appreciated it.
