Thanks guys,
Jon, I'll go on line and pull a wiring diagram and see if there is a relay at the rear and or in the front electrical panel. But I'll check the rear starter switch first. Keep you guys posted.
Jim, I'll start the coach from the rear and then turn on the ignition switch on the dash. I can drive the coach and all accessories work.
