Quote Originally Posted by Navigator
Debi,
On your Vantare's HWH slides what type of seals do you have, is it just a soild rubber gasket that flanges in and out with the slide movement? Have you ever had any leakeage problems? Would a hard rain or nasty weather cause slides to leak while in the in or out positions?
Tim
Hi Tim,
I have no idea what type of seals the HWH slides have--here is their website link: http://www.hwhcorp.com/roomexten2.html Maybe that will be more helpful to you? As far as weather, we have only been out in the rain with the slides out twice. We had a minor problem with high gusting wind blowing some moisture in but discovered it was around the window not the slide. With the slide in, the window is covered by the awning. I would buy another coach with slides without blinking--it is the only way to go for us. Haven't you found your perfect Prevost yet?
Debi and Bob-00
