Results 1 to 4 of 4
Thread: Changing pressure in main tanks
    Polk City, FL
    205
    Default Changing pressure in main tanks
    Good morning everyone,
    I think I have developed a problem in the governor controlling the main air compressor run by the DD. Prior to yesterday the pressure would only drop to 115 before the compressor would bring the pressure back to around 120-123. Now it will drop to around 105, then bring it up to 125-130. It appears the compressor is working correctly, but the governor is not functioning correctly.
    Any ideas?
    Thank you
    The new parameters you are describing are acceptable. However if it is a change from what it has been something is definitely going on and you may want to have a new regulator on hand. 20 bucks.
    The regulators can be adjusted to shut off at different pressures but I was unaware of any that did not allow pressure to go down to right around 100 even before beginning the process over again. Putting it another way that low pressure where it starts pumping air is not adjustable just the high pressure where it stops is
    Your current reg and the way it used to start pumping at 115 is IMO preferable but I have never had one that did that.
    3,782
    Kim,
    105/125 is good, but like Joe said, something might be going on if it has changed. Any truck parts or NAPA will have the governor.
    Here is one of my previous posts:
    http://forum.prevostownersgroup.com/...t=air+governor
    Petervs Guest
    Kim, did you by chance drive way up or down hill, like 5000 feet worth of altitude change? If the outside air pressure changes the gauge reads a little different because it is referenced to the outside air.
  1. Holding Tanks Level Monitors
    By Larry W in forum Ah Houston, I think we have a problem...
    Last Post: 03-20-2021, 09:55 PM
  2. Single waste tank vs separate tanks.
    Last Post: 09-05-2008, 11:47 AM
  3. Gray vs. Black Water Tanks
    By rff105 in forum Busted Knuckles and Greasy Jeans
    Last Post: 10-30-2007, 01:21 PM
  4. Water and Holding Tanks
    Last Post: 11-09-2006, 10:24 PM
  5. Changing Wallpaper
    By Jerry Winchester in forum Ah, Nice Coach...
    Last Post: 10-26-2006, 08:03 PM
