Results 31 to 39 of 39
Thread: Battery surprise!
  1. #31
    May 2008
    345
    Default update.
    I followed Jon's suggestion, did an equalization, made sure to set dip switches correctly. This was all quite easy to do. Batteries are still not lasting very long, though we are in some extreme temperatures right now, so I think my plumbing bay heater has been running constantly, which is a pretty good draw. I suspect I have a bad battery somewhere. Since Marathon charged me two arms and a leg for the batteries and installation, I may have a chat with them. The batteries are only a year old. That just seems too young to die.
    Jon, do I understand correctly.... if one battery is bad, the whole bunch is spoiled? Yikes. That's an expensive fix.
    Thanks to everybody for the help!
    Adam
  2. #32
    Adam, one bad battery does not mean the rest are spoiled, however if you read the link I previously sent, as well as Dale's post on his recent battery replacement you will see that mixing batteries of various ages seriously compromises the utility of the entire set.
    The bad battery obviously needs to be replaced, but if you replace just that one, the different charging needs between the new battery and the older ones is going to reduce their ability to serve your needs.
    Yes, replacing a set is expensive underlining why it is important to do all we can to extend their life, including changing the depth of discharge level for automatic generator start.
  3. #33
    BTW, I hope Marathon can go to bat for you with Lifeline. It sounds as though your autostart is functioning as set and intended by Marathon and that what is happening is possibly a warranty issue. I am sure you will need to get the coach to someone acceptable to Marathon and Lifeline to verify a failed or failing battery so you can get the problem resolved. Any delay on your part now likely makes a resolution satisfactory to you more difficult to obtain because time is critical in battery warranties.
  4. #34
    Aug 2007
    Grass Valley
    480
    Smile
    This thread is only one example of the value of not going it alone with a bus. My first bus involved going it alone for 6-7 years but doing so with great expense and mysterious problems. My stumbling onto POG brought a renewed excitement to owning and operating our bus. We use it a lot more and enjoy every minute of it. Meeting all the wonderful POGGERS over these past few years has added has added greatly to that experiance.
    Thank you all. We hope to continue with you for the next few years.
    Shirley & Harry
    Harry
  5. #35
    Apr 2008
    617
    Quote Originally Posted by hhoppe View Post
    Shirley & Harry
    Hey Harry does that include me to ???? Hope all is well wth you !! Sid Tuls
  6. #36
    Feb 2006
    Bristol, Tn
    1,647
    Well Stated Harry.
    Mr. Skiffer: There is another promo line for POG "You don't have to go it alone"
    Roger that!
    2008 Liberty DS XL2
    2023 Denali Ultimate
    My 6th Prevost
  7. #37
    dalej Guest
    Hey Sid, Harry is still mad at you, we'll let you know when it's safe to return!
  8. #38
    Mar 2008
    608
    Shirley & Harry
    Couldn't agree more Harry! I was about to be shaken down by Joe Schmukatelli's Mobile RV Repair and Wholesale Burritos when Truk mentioned POG. My right index finger was two knuckles into my nose trying to repair my Webasto when Mike Anderson stepped in and saved the day!
    John
  9. #39
    Aug 2007
    Grass Valley
    480
    Sid: I enjoyed our encounters er I mean conversations. DaleJ is wrong I was never upset with you. I even sent you an email exponding on our new found friendship. Black and white cows? you were kidding right?
    Harry
  1. Battery Basics ??
    Last Post: 02-01-2010, 10:23 PM
  2. So, that was a surprise ....
    By Ray Davis in forum Sparky's Corner
    Last Post: 05-06-2009, 03:27 PM
  3. Battery Draw
    By jkbriggs in forum Sparky's Corner
    Last Post: 01-26-2009, 11:55 AM
  4. AGM or Gel Battery
    By blacklab in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 11-05-2007, 08:07 AM
  5. MK 8D Battery
    By mikedee in forum Busted Knuckles and Greasy Jeans
    Last Post: 05-17-2007, 05:57 PM
