Results 21 to 30 of 38
Thread: Coach Batteries
    Huntsville
    3,135
    I'm impressed Gary. Low-tech confiugration with high-tech results! Great job.
    dreamchasers Guest
    I have looked at this post numerous times. Each time my amazement grows as to how applying simple techniques to get results. Being able to prune ideas such as these makes owning one of these huge machines much more manageable. This technique certainly goes along with my principal of Keeping It Simple!
    Thanks for sharing.
    Hector
    Sugar Land, TX
    1,307
    Great Job Gary De. You really made it look easy.
    I can hear everybodys mind whirling with their own ideas, of when they can use your idea in their own bus.
    Gary S.
    The Lifeline batteries are 162 lbs each (GDL-8DA) http://www.lifelinebatteries.com/rvd...ebatteries.php
    A little heavier than the Deka Gel Batteries.
    I had them shipped to my office and the shipper dropped them into the back of my Truck.
    I had looked into several other methods of removing and replacing my batteries but here was nothing I could find that would reach into the center of the storage bay so I spent a while assembling my Pole and Lever method.
    What inverter do you have in your bus?
    Will it be easy to change the charge settings from the gel type to the new glass mat?
    Gary, you indicated above that you bought GDL-8DA. I don't think that is a typo as the P and D are on opposite sides of the keyboard, what are the specs of the GDL-8DA, or should it have read GPL-8DA?
    May 2006
    Diamondhead
    447
    Default Great Battery job
    I am just lucky I guess, as my batteries are on a Joey bed. You just pull it out and lift the batteries up! You would think that some of these new and fancier coaches would have this wonderful feature!!!!!! They must have known that I have 0 mechanical ability and gave me a break.
  6. #26
    Hi Jim. Heart 25 Inverter/chargers. Yes, it is GPL. The settings for the Lifeline are so close to what the Gel settings were, I left them as is. The Heart 25 is a 3 stage charger, and the requirements for charge were 13.5 to 14.4 volts which is within the specs for the lifeline.
  7. #27
    Default Inverter Settings
    Gary, my inverter settings are:
    Left / no 1 Right / no 2
    #1 off #1 off
    #2 on #2 on
    #3 on #3 on
    #4 on #4 on
    #5 on #5 on
    #6 on #6 on
    #7 off #7 off
    #8 on #8 off
    are yours the same?
  8. #28
    lewpopp Guest
    About 2 months ago upon arriving here in Fl, I called Lifeline to see what the POG cost ov the 4ds would be and at that same time they informed me they had a price drop.
    Enough of that, I found the closest place I could get the batteries was in Charlotte NC. shipping would be approx $150 or more and I would have to pay someone here several Lewbucks to put them in. I'm not beyond that, but the local rv mobile people don't even know what Lifeline is. Just the same, I have decided to pas thru Charlotte on the way home in May and have whomever they suggest put them in. I am seriously thinking og going from gel cell to AGM. I was told by Jon that if I had good service from the gel-cell to stay with them. I don't always do what I'm told, but if enough of you guys think the new owner would readily except either, well I may reconsider. (note: how I spelled reconsider, not reconcider) Here I go again, ADD setting in again.
  9. #29
    sawdust_128 Guest
    Gary:
    Nice! Just curious. Would an engine hoist work or is the boom too short?
  10. #30
    3,783
    Louie,
    I think your better off with AGM's, even Lifeline says the charging cycles of AGM are about twice what you get with Gel and that means they will last longer.
  1. Batteries Again?
    Last Post: 03-18-2010, 02:44 PM
  2. Batteries
    By gmcbuffalo in forum Electronic Gizmos, Computers and Communications
    Last Post: 07-08-2009, 01:17 PM
  3. Batteries
    By garyde in forum Sparky's Corner
    Last Post: 06-11-2009, 01:05 PM
  4. House Batteries
    By Richard Barnes in forum Busted Knuckles and Greasy Jeans
    Last Post: 06-02-2009, 12:52 PM
  5. Batteries
    By garyde in forum Engines, transmissions, axles and wheels
    Last Post: 07-27-2008, 09:18 PM
