I thought about it and don't think the cap needs to purge after all and in fact does not ever purge. I was thinking about the spring loaded cap and got myself mixed up but that spring is just helping keep the cap on tight, not opening and closing to allow the overflow to purge I'm pretty sure. I think when the overflow get's full, the water simply finds it way out through the top hose. Jeez, now if that's the case the system woudn't be sealed up and create preassure. Ok, back to needing clarification whether to let some water out and give the overflow some breathing room.
