In order to prevent posting a new thread I just did a search for "coolant" and found this existing thead.
My sensors (ordered complete set at Jon's article suggestion) finally arrived today and installed what I belive was the faulty one but will road test tommorow. Now, while we were waiting, my wife keep saying, "What about the water........it could be low water.........we should add water". So I added a gallon of water to the overflow tank. It was half way at the site glass as the time of adding it. The conversation about "the water" continued. No amount of explaining would close the hole about how the ebb and flow of the water when hot and cold and that that overlow tank didn't need to be topped off. Finally, I couldn't take it anymore so to end the "We need more water there" conversation, I let her watch me dump yet another gallon of water in. This brought the level all the way to top and overflowed. I figured a half gallon or gallon would blow out through the overflow hose and I got to end the insanity. BUT, the cap went on and off sort of hard and I just got done reading Jon's coolant change article and it got me to thinking that if the cap fails to open and allow the water to purge, something else may give way and blow a gasket in the system. So I think I should siphon a gallon out tommorow before shoving off. I think the first gallon was ok to add to get it above the site glass but not the 2nd.
Can someone confirm if I'm correct to leave some empty space in that tank ?
