Maybe this will put this subject to rest:
Effects of Time and Temperature
Tire inflation pressures change due to time and temperature. Tires lose about 1 psi per month due to air escaping through the rubber as it stretches. If you were to check your tires only every six months, it would not be uncommon to find them under inflated by as much as 6 psi. Tire inflation pressures also fluctuate with changes in the outside air temperature. This occurs at a rate of about 1 psi for every 10°F (plus or minus). So the tires you set correctly with an 80°F ambient temperature will be under inflated by 6 psi at 20°F.
Here is another site that deals with racing tires.![]()
