Originally Posted by
0533
I left out of Gainesville Fl. yesterday morning for the short ride back to Jupiter. The ride went smoothly (30 mph wind gusts). As we left 95 for the ramp into Jupiter I noticed a loud howling or squealing sound coming from the back of the bus. Nothing on the gauges showed me exactly what was going on but I knew it was not necessarily good.
I decided to get off the road and limp into my slip near home a few miles away.
The noise was deafening now and when I came to a stop next to my slip I noticed that both brake gauges were now at 80lbs. but holding there. I looked under the to see the same old line and valve hanging down next to the drive shaft air streaming out of the open end, plus the valve stem had been severed off at the threaded end.
I can not understand why this has happened again, there does not to appear to be a good reason for the failure twice in the same location.
I am not certain how to make temporary repairs at this time. want to stop the leak detach the lines to the Toad Brake valve and seal the main/Air force One Air tank leak so that my main brake air tank is not continually drained down by the demand on the open valve port on the Air Force One tank.
If my attachment has been uploaded you will see where the problem is.
I want to get under the bus to examine this better, plan on tilting the airbags over to one side, placing the Prevost Jack on the high side for safety and then detach the dangling valve, and try and screw into the Airforce One Air tank some type of threaded screw to seal the hole, any ideas.
