Assuming the rear hub seal is OK, it could be the gasket behind the cap, the plug, or the seal between the plastic and metal has failed. Unless it is the plug, a new gasket available at a truck parts store and RTV silicone sealant is all that is needed.
My RH cap leaked between the plastic and the metal so I removed it, cleaned it completely with solvent and sealed it with a thin bead of RTV silicone. That was 4 years ago and it hasn't leaked since.
Clean it up real good and go for a drive. Then see where it is leaking. I assume you know the plug needs to have that pin hole open otherwise pressure builds up in the hub.
