Results 1 to 10 of 81
Thread: Air Conditioning/Inside the Pipes
Threaded View
  1. #2
    Default Almost Chilly
    Jeff, we are a couple of steps closer to otr a/c. While nosing around inside the dash repairing the wiper squirters I noticed alot of oily resedue around the ducts below the evaporator so I pulled it and had it tested, its o/k. I then ordered the expansion valve that the evaporator threads into Im pretty sure this was the culpret because the hoses are good, either that or it was a loose fitting. Were going to vaccum it down again and if it holds vac this time. I am undecided if I will install the freon, have a local shop do it, or take it to a prevost charter co with a service garage that Im sure has done it a thousand times. Having spent almost 600 bucks for the R-12 I dont want any mistakes. Also I remember seeing somewhere you posted correct high and low pressure levels what were they again. One more thing, Jon also suggested I replace the compressor seal since the system is currently empty and could be a potential leak, it has also has arrived and needs to be installed. Lets get real specific like we know you can! Thanks.
  1. Entrance Door Won't Open - "Barney" Inside
    By mcirco in forum Ah Houston, I think we have a problem...
    Last Post: 11-04-2012, 10:51 AM
  2. Covered/inside storage in North Georgia?
    By michaeldterry in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 10-16-2009, 02:41 PM
  3. Air Conditioning Question
    Last Post: 06-08-2008, 06:51 AM
  4. Avoid frozen pipes
    Last Post: 03-12-2008, 08:42 PM
  5. Water pump leak / replace with copper pipes
    Last Post: 03-04-2008, 10:11 PM
