This time it's the toilet. Was working fine last night, this morning no water in the bowl. The valve opens the blade but no water in the tank. Water is fine everywhere else. Where to start?? Damn!
Ted,
Which model do you have ?
Alek
Ted,
May we assume you have water pressure to all other devices?
OK, got it fixed. Sorry to bother you all again. Jan had thrown the aux. compressor breaker last night and the air pressure would open the blade but not enough to allow water in the bowl. KISS usually works.
switches is bitches.
On a related issue, I had toilet issues and no dealer within stricking diance or my brand. You solved it yes, but have any of you, with air flush systems, that you leave the air pump on, you hear it cycle from time to time ? In my case, it was likely the rings on the air pump. However a check value at the right spot underneath in the bay, totall eliminated the issue instea of replacing a pump that produces pressre fine, but had a small leak. Not in a hose, but through the rings on the pump. It cycles maybe once a day now. The check valve was a 99 percent fix for the issue for now.
