Originally Posted by
JIM KELLER
" What causes an overvoltage [ if the meter is correct.] Well, several things could cause this problem. One bad cell in a battery as previously discussed could be a problem. A regulated charging system detects a weakness in a battery cell and tries to make up for that weakness by overcharging. Consequently the other batteries in the system suffer from the excess voltage and die a premature death.
" What causes a discharge when the genset is on." Prehaps there is no discharge. 24 to 25 volts seems like a normal operating range. Like Tom said, find out what the light on your dash means and let us know.
The best way to understand your electrical system is to start with a hand held meter. Record the voltage of all systems with the bus unpluged from shore power. Get a reading on the genset battery, the house batteries and the chassis batteries. Then, one by one start individual systems up and check the readings. Example, plug in then unplug. Start the engine then shut it down. Start the generator then shut it down. By isolating the systems you will get a better handle on what is going on and make it easier for someone like Jon or Tom to take over and help you.
