After talking to Prevost Parts, I was referred to Bill Jensen to get a definite answer on the jacking points. He was under a coach, and I was under mine, so I was able to verify exactly where the points are.
As I suspected, the points in the first picture I posted are the correct points. If you notice in the picture, there is a flat spot on each side where the insulation has been removed. The spots are at the rear of the "A" shaped bracket in the picture, about 16" from the center on each side. Bill said on some coaches, there is a plate on each side, on others (such as mine) there is no plate, just a flat spot.
