Results 1 to 6 of 6
Thread: Alt Belt Tension Gauge
    Default Alt Belt Tension Gauge
    Unlike you lucky late model guys, I still have the manual belt tensioner for my Alternator. The Prevost Manual says to adjust to 200 lbs using the Prevost Belt Tensioner Gauge, part #011742. Up to this point, I just kinda go by feel, but wondered if anyone has seen the Gauge or has a better way to assure the tension is within a reasonable adjustment. It does flap around at idle, but smooths out with just a few RPM's, no matter how you adjust it. I've seen others do the same thing, so I assume it's normal.
    And NO, I'm not going to upgrade to the auto tensioner to the tune of 1,600.00 Mango bucks just so I have a new shiney part highlighted by neon lights in the engine compartment.
    Anaheim
    566
    Tom, I have the same as yours, I set them the old fashion way when I changed the belts 15,000 miles ago and they still feel ok.
    I also think the OE adjuster will work fine for my life with this coach.
    Kevin
    Ditto what Kevin said. With the air tensioners there is some give to the belts ( I usually shut the engine off when I do this) so I don't think they have to sound like a violin string.
    lewpopp Guest
    HEY TRUK
    What's this with the Mango Bucks. You are reverently referring to Lew Bucks and don't forget it.
    Mango bucks are earned from his harem of women. We do not want to be associated with dirty money.
    Lewie,
    After your Prevost front axle experience, I thought the Lew bucks dried up, but I stand corrected! But, given the choice between the PRETTY Mango bucks and your AARP bucks, you lose oh great bus driver. Now please tell me your still on the dark side with us and not turning into an LED weenie?
    lewpopp Guest
    Oh, my dear bus driver, I do use AARP Bucks now and I still haven't gained a love for smart assed Republicans that drive busses. Ho Ho, I said it first. That's my buddy Bill Clinton. You already know what a Bush is.
  1. pyrometer gauge
    By gmcbuffalo in forum Engines, transmissions, axles and wheels
    Last Post: 06-15-2009, 01:35 PM
  2. Calibrated Air Gauge
    By 0533 in forum WHERE TO FIND STUFF: Links and Resources
    Last Post: 11-14-2008, 07:23 PM
  3. Alternator Belt Tension - Gauge
    Last Post: 07-27-2006, 09:33 AM
  4. Fan Tension Pulley & 24V Charger
    Last Post: 03-21-2006, 05:04 PM
  5. Belt Tension Air Bags Leaking
    Last Post: 03-09-2006, 09:48 PM
