Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: melted wires?
    AJ, don't write off the battery tender yet. You can always replace the wires. Three year old batteries can still fail so it is worth keeping your eye on them. If you do not have a good multitester now is the time to get one. It is a tool you should not be without.
    As long as you will be at PSL for a few days, disconnect the chassis battery terminals and clean things completely. Leave the terminals off for a few days and monitor the voltages of each battery. If any of them show a voltage drop greater than the others that battery is suspect. Fully charged batteries should sit at 12.6 to 12.7 volts. Corrosion is often a current path to ground and will discharge a battery so as Gary says this is an area that requires periodic maintenance. Come to Sevierville. We can give some more help.
    Greg's comment is correct, so if you do replace the battery tender wires just make them the correct length to do the job.
    AJ,
    I have a couple of appointments today but should be available by mid-afternoon. I'll check with you then.
    In the mean time, as most have suggested, it's a good idea to disconnect the suspect wires and get things cleaned up.
    See you soon!
    3,782
    Load test them while you have the cables off!
    dalej Guest
    Tom, are you bringing your load tester to the rally? Or does anybody carry one on board?
    I will have my DDEC reader (II and III), my leak detector, my load tester, and my electrical testers (multi and clamp) for impromptu repair jobs or testing of coaches.
    The rental rates are very modest.
  6. #26
    AJ,
    How did you make out with your wires? I stopped by a couple of times but no one was home. Sorry to have missed you. I'm hoping that means that you got everything resolved and were out having a good time!
    If you still need help, just let me know.
  1. Spare front to back Wires
    By billbunch47 in forum Sparky's Corner
    Last Post: 03-12-2008, 10:07 PM
