Originally Posted by
Jon Wehrenberg
Knowledge is real power, especially when you encounter a problem and you are away from home.
I would suggest that every owner should have available or accessible as much information as possible about the coach and its systems. If a problem is encountered on the road, it can be expected that the closest service will not be your converter or a Prevost Service Center.
Because when you are in Spearfish SD and your frammistan appears to have failed, you need to be able to convey to the guy from the local Bait Shop and Freightliner service where the frammistan is, how it is hooked up, what it does, and what you need done. Obviously I am stretching it a little when I think we need to get into specific detail, but it does help immensely if we can provide to the service tech pneumatic or electrical diagrams, or access to parts lists or service manuals. Even "experts" are involved in on the job training, on your dime, and if you have diagrams such as what Hector is seeking it becomes much easier to problem solve, and considerably less expensive.
