Wouldn't a cheap, 50ft roll of garden hose, connected to the Macerator outlet, work just as well?
Some of the crap hoses are so cheap they're almost disposable...
JPJ: You do take trade ins on the dodo poop pipe dont ya?
Roger that!
2008 Liberty DS XL2
2023 Denali Ultimate
My 6th Prevost
For those with a working macerator, that's the slickest deal of all.
The SF-10 is rated for 10 years of continuous industrial use.
No trade ins.
The Ultimate Coach should have the ultimate...
Paul, the picture JPJ posted with the fire hose is his personal plumbing system over in Mount Olive Shores. Special deal he worked out with the gov't.
Speaking of waste dumps where do the Entertainer bus go to dump their tanks. I seen them at Prevost facilities driving over a hole in the ground and dumping. Where else could they go to do this? No hose female bus, male buses use hoses.
GregM
When the bus driver has taken the passengers and equipment to the site, the driver will take the bus wherever he has to go to fuel it up, dump tanks and take on fresh water, plus get it serviced if necessary so it is good to go when the show is over.
Often the arena or show site will have a sewer cleanout that can be opened and used for dumping, unless the bus is owned by the Dave Matthews band, in which case a bridge will work.
Jon you omitted a vital point of the Mathews method. The passing sightseeing boat positioned below to keep from contaminating the river.
Joe, you seem to attribute the environmental concern shown by the driver of the Dave Matthews bus to skill or experience. I think he was lucky he did not pollute the river, otherwise he would have gotten into trouble. Luck, not skill was at work here.
He would have been luckier if it was loaded with politicians.
At least now I know the purpose for an open grate bridge deck!
And here I thought it was to play havoc with all the bikers trying to stabilize their handlebars.....
A friend of mine owns an entertainer coach (it was supposedly owned by Trisha Yearwood)
He indicated to me that entertainer coaches would (if they were traveling in rurual areas), simply pull over to the side of the road, and "let it (d)rip" into the ajacent corn field. Not really sure about that, but it makes for a story ...
I have a macerator on the new bus. I have not yet tried it, but would like to try a regular garden hose at home, and see if I can pump it into the home sewer connection? Finding a real dump site here in CA ain't easy. Generally I try to drive by Prevost before putting the bus away!
