For those of you that like to work on your bus i.e. shocks, air bags, air valves or change oil and
do the service work, you need to use these stands.
For those of you that want to use stands, you just might need a aux compressor to raise the bus
all the way up so you can set the stands and work underneath with out the feeling of what if.
The height is always best if its all the way up and then let it settle a bit on the stands. When you
are ready to move the bus it's nice to have a air compressor that will pump up to around 135 to
raise the bus to get the stands out. Then you can lower it below ride height and then start the bus.
Sometimes when I'm in a hurry to move the bus I use my air over hydraulic jack to raise the bus
to remove the stands. Front first, remember.
