AJ....Prevost made the retrofit to larger air bags in the early 90s. Apparently yours did not get them. I cannot remember the details, but I do not think any welding or modifications were involved. If you contact Prevost parts in Elgin they can answer your questions about what may be involved. I think the newer air bags were referred to as Mae Wests at the time.
The cost should be 2 hours labor and about $290 for the two air bags. If your current air bags are only 3 months old (and they will have a label with the date on them to show a buyer that) offer them to any POG member at a price fair to both of you.
A general comment about the aux air pump and water. We have discussed on this forum that if a coach owner relies a lot on the aux air compressor the aux system needs a "spitter" or water trap immediately downstream from the aux compressor so water can be caught and drained before it gets into the aux air system. People who full time in the coach would be the typical owner that could be in need of this spitter.
The consequences of water in the aux system, especially introduced from the front can be very substantial. There are at least 4 solenoid valves and several Norgren valves that will get screwed up if they get filled with water, and they will.
Joe C. has lanyards and valves on the bottom of his air tanks and I would urge that those get added (I hope Joe jumps in here) to the wet tank in the rear, and the aux tanks in the front to keep the system dry.
If you get water in the system and it freezes all sorts of bad stuff can happen.
