Any ideas?
On the drivers seat. Doesn't light or seem to do anything.
Any ideas?
Mike, could it have anything to do with the graphic depiction of a seat movement below it that is blocked for your installation, due to a lack of room behind the seat???
Sorry Jim,
No relation.
Thanks
MIke
Hi Mike. Where's the white arrow? Anyway, it probably was a seat heater.
They don't last very long. I had a Range Rover ,which after the 4 year warrenty was out by a month, the seat drivers heater when out. I think it was $400.00-$500.00 to fix.
Looks like it is an illuminated switch.
If you are curious pull it and check it for power.
hello mike...is that possibly a lumbar support switch...similar switchs, 2 on my driver seat, adjust lumbar support...could be....shookie
Mike, I vote with Gary on a seat heater. I just ordered 2 packs of the clean sheets, think that should last a few weeks?
I almost have the new bus back on the ground, I will try to take some pictures before I get the wheels back on.
Kevin
I don't have it on my coach, but I vote with the bun warmer contingent... You can get them in the aftermarket for passenger cars for $70 a seat, that includes all wiring and switch for one side - I've had my ISRI apart and see no reason why the passenger car version would not work in that application.
C'mon, you all know it's the integrated fan and suppressor for Taco touring and the associated flatulence restriction!
Mike,
I have the same switch on my seat and I can't tell that it does anything nor does it illuminate.
