Results 1 to 3 of 3
Thread: Code Reader
    Jul 2007
    East Texas
    946
    Default Code Reader
    I have hired a DD guy to do a code read on an 8V92T that is in an older Liberty. My question is, just what am I going to learn from this adventure? I think it will show a history of engine temps and RPMs, but what else should I expect for my $75 bucks? And, what would be acceptable numbers? At what point would you say "nope, I don't want an engine that has run ---degrees or over ---RPM." Any guidance here appreciated.
    Nichols Hills
    2,465
    It will show any active codes (errors) and that is good information. It will also show engine hours / PTO hours / set points. You can also see if the codes were erased in the past (reset) and when.
    Jeff Bayley Guest
    Default Info on reader
    I just had to replace the computer on my bus. The memory had failed in it. All of the former history is gone now. The DD guy asked me what I wanted to put for mileage. I told him to put what was on the odometer to keep it correct. But evidently, this could be rolled back if someone wanted to roll back the dash odometer to match. I don't suspect this would be all to common, but to be sure, you could check with any DD dealer with that buses VIN (I would thin) to see if the computer had ever been replaced in it since they should only be the ones who could have done it.
  1. Pro Driver Code??
    By GDeen in forum Sparky's Corner
    Last Post: 12-28-2009, 10:31 PM
  2. eNEED DDEC READER for 1999 SHELL
    By Coloradobus in forum Sparky's Corner
    Last Post: 08-24-2009, 12:14 PM
  3. DDEC Fault code reader?
    By Ray Davis in forum Electronic Gizmos, Computers and Communications
    Last Post: 09-20-2007, 06:51 PM
  4. DDEC Reader / LED Bling
    By Loc in forum Busted Knuckles and Greasy Jeans
    Last Post: 04-07-2007, 10:00 PM
