Results 1 to 10 of 39
Thread: Tire Replacement
Threaded View
  1. #13
    rff105 Guest
    Just received some tire quotes we have some uneven tire wear in the front end and the right side drive tires are worn more than the left side which look brand new. The bus pulls a good amount to the right even on flat road with no crown. So we are looking at getting an alignment putting two new 365s on the front changing out the 2 old drive 315s and putting the best two of the four 365s on the tag.
    New tread depth on XZA 365/70R22.5 is 19/32
    New tread depth on XZA1 315/80R22.5 is 18/32
    All tread measurements are not taken to wear bars and in the center of tires. Take 2/32 off each tire for wear bars.
    Steer – Driver (12/32) Pass 11/32)
    Drive – Driver (Out 16/32)(In 17/32) Pass (In 7/32)(Out 8/32)
    Tag – Driver (13/32) Pass (11/32)
    Could the slightly larger drive tires 17/32 vs. 7/32 contribute to the pull to the right? Would you mix the new drive tires with the old by putting the 2 new on the outsides, or just put the new set on the passenger side duels because it seem like that side wares faster due to road crown?
    Michelin XZA 365/70R22.5 are $630 tire only, 6 week backorder
    Michelin XZA1 315/80R22.5 are $605 tire only, 8 week backorder
    This bus only has 30,000 miles on it seems like a lot a tire wear from reading other post here where age comes into play long before tire wear.
  1. Aux Air Compressor Replacement
    By Johnny in forum MISCELLANEOUS ITEMS
    Last Post: 01-06-2010, 07:09 PM
  2. Replacement Hoses
    Last Post: 01-21-2008, 09:38 PM
  3. ZIP DEE Replacement
    By garyde in forum Prevost Shells and Prevost Car Company
    Last Post: 08-06-2007, 02:20 AM
  4. Tire Pressure Monitoring for $4.99/tire!
    By Ben in forum Engines, transmissions, axles and wheels
    Last Post: 03-27-2007, 09:59 PM
  5. Air Bag Replacement
    Last Post: 02-19-2007, 10:05 AM
