Hi, I'm a new member, I inquired earlier about engine code readers and VMSPC, and in the responses was asked to tell how it worked if I bought one....
Silverleaf electronics sells the reader for their glass dash that shows on a laptop instead of their $$$$$$ panel, for $395.
It works with my DDEC 2 and any later elecronic engine from all manufacturers, and gives a dashboard like display with all the electronic info that a more expensive code reader gives one line at a time, in a form that you can use going down the road.
On the DDEC 2 I get temperature and pressure, Turbo boost, volts, GPH, MPH, fuel totalizer, throttle position, cruise setting and more.
Out of the box I learned my tach reads 100-150 high at max, my oil pressure is better than the gauge shows, I burn 10 GPH at 65 miles per hour and a lot more. On the DDEC 2 I do not get odometer, but they say some software magic might get that too.
It is less expensive than a code reader on ebay, and it works on any engine.
I hope you don't mind the unabashed plug, but having paid real money to get a shop to read my codes previously, I am impressed with the product. It takes minimal computer skill and their telephone support was great
Jim
