Thanks, Jon.
I checked the main electrical panel and verified that we were getting AC, since the cruise airs would work fine.
I noticed that the Heart Inverter panels (both) indicated an "overload" condition. So, I switched them off for a moment, not at the breaker but on the inverter panels, and then back on. They came back up looking "normal" and apparently started charging. I shut down nearly everything, cruise airs and all and still was showing a load of some 40 amps per line, so the chargers were apparently working as there should have been no other explaination for that high of a load.
Looking at the guages at the dash indicated that the house batteries were, in fact, coming up in voltage, as they are now at just over 13 volts and the "house amps " is showing about 150.
I'll monitor the house battery voltage and see if it stays put. If it starts to drop, I guess I can assume that either the chargers have stopped or the batteries simply won't hold a charge?
Thanks,
Paul
