I guess my main question is ... Why, when plugged into campground, does my AC Power in coach go off when I turn off the Inverter switch on the Heart Control Panel?
According to Documentation ....
"The internal transfer switch will continue to be engaged with the switch off and AC power will be available at the output of the unit. If AC power is removed the unit will not come on as an inverter."
Still puzzled...
Also, with regard to water... when connected to park water and pump is off I get water flow inside but at very low pressure. Not enough for a shower. I will stick with the pump.
Lee
