Prior to POG2 I purchased an EvenBrake system from Roadmaster. This is one of those system which go in the toad, and push on the brake pedal. I got this because I wasn't sure I'd keep this toad, or want a more internal supplemental braking system.
With POG2 trip, I had no problem. But, going to POG3 it had been 6 months since using it, and I didn't quite read the directions. When stopping for fuel at a Flying J I took the opportunity to disengage the brake thingy, and run the Honda through it's gear pattern to be set for another 300 miles.
I was idling for the last couple of minutes, and put the brake system back, and ran the test which it pumped the brakes three times. All is good, right? Not!
I got out towards the freeway, had to hit my brakes a bit, and next thing I here is tires screeching, smoke coming from the toad, and the brakes didn't release for probably 10-15 feet.
Ultimately I had two flat spots on my fronts. Jim and Chris reported on the CB that my Honda had been enveloped in smoke! The bus had zero problem dragging my poor little Honda, who was kicking and screaming behind me!
It's then I remember that the brake test is supposed to be done when the engine is off, to bleed off all extra vacuum. I had tried to save time, and ran the test while idling. So, I had a fully charged vacuum when the brakes engaged.
That's one I'll remember to do in the right order!!!
