Ray, CONVOLUTED is indeed an understatement! IMHO. JIM
Jon,
Rather than re-uploading pictures you should be able to edit your first post. In looking at the two pictures you uploaded, the attachmentids are 1060 and 1061.
Change the two lines (click on edit) to:
[attach]1060[/attach]
[attach]1061[/attach]
and hopefully the first post should be fixed.
You da man, Ray.
I have to try it again to see if I can do it from the beginning.
For that brake adjustment you need to come to Casa Del Grease Pit.
This is what the guy looks like sitting in his car
Attachment 1170
And here is the same guy relaxing in front of his computer.
Attachment 1171
OK, now what?
Now what??? Now what???? I sure hope that doesn't break or get stuck in a deep crevice . [/I]
my first attempt at posting a picture
95 Liberty
03 BMW 650 CS
Jon
Your pictures come up as thumbnails and that tells me you are not in the standard editor setting.
Go to user CP control panel, settings and options, edit options.
Then when that comes up go all the way to the bottom of the page and click on that box and standard will be 1 of 3 choices. Get standard in the box making sure to click out the blue background field to white before exiting, finally clicking save changes at the very bottom of the page.
This should also change your screen for posting to now include additional tools and smilies. After you insert your pictures, by using the paperclip in the tool bar above, take your icon your moving with your mouse and put it at the end of the first attatchment and click. Then hit Enter key on the keyboard and that should put you inbetween the pics.
If this is all the case give a reply and we'll continue. My opinion is this mode is easier to post up pics, you can preview them this way.
Let see if this works.
Here's number two:
