Hi Jon,
I am not an expert on pre DDEC or DDEC 1 systems, but I can not imagine that the fuel supply is controlled directly by the throttle position. The engine would flood out if you opened the throttle too quickly, the metering control has to sense the air pressure in the cylinder or going into the cylinder and respond to that.
Perhaps someone else will have a definative answer.
Peter VS
