Results 1 to 8 of 8
Thread: Buying a bus and have some questions.
    Jul 2026
    Birch tree
    8
    Default Buying a bus and have some questions.
    Hello all.
    Im looking at buying a coach sometime this winter and have some questions. The first hurdle is, we are a family of 7. My oldest is 15 and the youngest is 5. So that sets the tone. Obviously that puts my purchase in a very niche category. Ill start by saying ive looked at a bunch of RVs. We looked at class A and super C. The problem as you might have guessed is most Ravs are built for 2. Others are have a couple bunks. This still leaves half of my kids without a place to sleep or sit when not sleeping. I dont want any sleeping on the couch, because this leaves half the coach useless half the time. I've thought about converting a coach and putting in bunks. However, that would leave a pretty wonky floorplan. So, that leaves me to think an entertainer coach to be the only logical choice. This is where the questions come in. I've looked at numerous coaches and test drove a few. I've looked at everything from late 90s to mid 2000s. I plan on actually using the coach and not just letting it sit stationary for months on end. Because of this, I think I would prefer a no slides coach. Less things to go wrong and I dont see the point in the added floor space. I dont really need more floor......for anything. I really like the star coach layout, which usually have 1 or 2 slides. I like this layout because it has everything I need. Now we get to the crux of the issue. The star coaches are usually xl2 chassis and start in the high $200s. All this is fine, except they all need quite a bit of work too. So add another $50k or so on top of that. Ill be honest, the thought of spending $300k and then having to deal with the near certainty of delamination doesn't really appeal to me. So, this leads me to an xl chassis. I can pickup an xl chassis for $50k. Put a whole new front end under it and redo whatever i need and have about half as much in it. I dont feel a need to spend more just to spend more. They both have the same chassis more or less and the same exact drive train. I dont want to spend another $200k just to get a nicer couch or interior that isn't some funky 90s color. I can sit on a blue coach just as easy as a black leather one. If I go the riveted route, I will have to add alot. Entertainer coaches are meant as a mode of transportation and lack any motorhome amenities. I will have to add a shower and redo the plumbing
    The toilets aren't meant to be used for #2 in them. So ill have to redo the black water system. I know that prevost went through a few iterations of the ifs. If I find a coach I like that has a straight axle, beyond turning radius, is there a downside? Or should I just spend the extra $200k or so and go with the star coach and call it a day? I Obviously dont want to spend more than I have to and I have no problem doing whatever work needs done. I personally see no difference between a 1999 and a 2008 other than one has a nicer interior than the other. So, is a nicer interior worth triple the cost and no DIY? Also, entertainers dont have awnings, but most star coaches do. So thats another add. I need input, please.
    Edit: I want to add more to this. Because of our family size a toad is also a problem. My wife has a transit van and it obviously can't be flat towed. So that leaves me with two options, a trailer or a separate toad. So, my question here is, to trailer or not. I know overall length is obviously an issue. Or I go buy a suburban for the sole purpose of toad use. Obviously the trailer is the cheaper route, i just dont think its the best.
    Dec 2019
    Brodheadsville
    322
    Hello Shooter,
    A coach may not be the way to go. A fifth wheel trailer could solve your problem with sleeping space and the need for having a vehicle to explore with vs. a toad. I have a friend with 3 children and he has a nice fifth wheel and they get around comfortably. Keep in mind also. The low rider 45,000 lb. coach has its limitations with access to uneven camp sites and places to go. Although traveling in a pick up means all seats will be filled. That might be interesting after a 3 hour ride! Cheers!
    1995 Liberty XL
    Chris & Sara Jo Behrens
    Jul 2026
    Birch tree
    8
    Can't go towable. In fact ae got rid of our 5th wheel when the 5th kid was born. The truck fits 6, we have 7. So thats out of the question.
    Dec 2019
    Brodheadsville
    322
    Hello Chris,
    I had a suspicion you already tried a trailer already. You do have a unique situation. I never heard of Star coaches before. I was very curious so I read everything on their site and looked at every coach they had available. They don't have coaches for sale but it gives you an idea what you need.Sleeping arrangements would be perfect with each child have their own space in an entertainer coach. I noticed that some have a bathroom and minor cooking arrangements. Some modification may be possible there with a small range and small frig. I have a microwave/convection oven that is a huge help. I noticed they all have a rear lounge area. That could be customized for you and your wife's personal sleep area. So, question is as you mentioned how much should you spend, etc. I still cant answer that question but an entertainer coach with some major/minor modifications might be the way to go.
    Give this guy a call. https://www.legacycoach.com/. Brandon Kendall sold me my coach. Good honest guy. He may be able to locate a coach that could come close to what you need. He does not specialize in tour coaches but no doubt he knows where to find them. There are also numerous entertainer coach sales companies out there. I'm sure you drove that route already.
    As far as a toad. You could pull a suburban with no sweat. Stick with a Prevost shell. You can always get parts and if you can find a liberty entertainer coach they are still in business and parts can be had.
    Hope that helps. Let us know how you make out.
    1995 Liberty XL
    Jul 2026
    Birch tree
    8
    Thanks for the reply. Weve looked at so many coaches over that past month....its not even funny. Test drove a few aswell. We thought about trailerimg ny wifes van, because we already own it. However, after talking with several folks on that front, we decided thats not the way. So yes, we will be buying a suburban just to leave behind the coach. Honestly, I really see thar as the only real option. I struggle with the cost thing because of value, not really finances. As the cost goes up, im not seeing any real benefits other than things get more shiny. I dont really care about that. Obviously everyone likes to have nice things, but to what end. What im getting at is, what is the increased cost buying me other than bling? Still looking to buy at the end of the year and have seen a few coaches we've put on our short list. The star coaches are really just bunk model coaches. The just tend to have 6 bunks instead of the 2 bunks on normal bunk models. They have all of the amenities of a normal rv, unlike entertainer coaches like you mentioned. Were still on the hunt. Honestly, I am scared of the xl2 delamination issue. So, we might end up with a riveted coach. Unless I see something I just can't pass up. Who knows.
    Dec 2019
    Brodheadsville
    322
    I have read several articles about the delamination issues. They had problems through certain years. You would just need to research that. I am partial to the SS riveted years. If you enjoy the aspect of a classic/antique model coach then the SS riveted is the way to go. You can settle on your choices or select a coach that needs a little fabrication to meet your needs. Before you purchase anything you need a professional inspection. I can give you the best person to do that. I have had a personal interaction with this person. Get an inspection before you buy!
    1995 Liberty XL
    1,053
    I agree with Chris. Legacy Coach is a good resource. I have done business with them several times and have always been treated well. They are just good honest people.
    A past frequent contributor to this site - Joe Camper - worked on the suspension of dozens of coaches. He always said that he preferred the straight axle. So, if you find the right bus and it has a straight axle, drive it and you might like it.
    I agree that there is not much value difference between a 1999 and a 2008 if they are both in good condition. As Chris said, get a professional to review the shell, suspension, drive train and all of the interior systems. If you find the right coach and it is older like a 1999 and it is in good condition, I would not hesitate to buy it. We have friends that have newer coaches and have put more money in them than we have put into ours.
    I agree that the newer more complicated coaches do not necessarily add value, especially in the context of your posts and preferences. They can be difficult to work on, can require specialized technicians, are difficult to do yourself, etc. etc.
    We also have a no slide coach. I do not want the maintenance cost or the inconvenience of getting ready to leave a park and having it malfunction. However my wife and I do have to choreograph our movements especially in the morning to keep from bumping in to each other. With all of your kids, more circulation space may be worth it. If you decide on slides, do your research on the various manufacturers. They are not all the same. For example, some slide seals can be replaced with the slide in the coach and some require the slide to be removed.
    With your unique requirements, It seems like you either get an entertainer and add / upgrade the amenities or you get a non entertainer and do major renovation to add the bunks. If it were me, I would be looking at them from a renovation perspective. How much work / money would each option require? I would not be surprised to find that it was cheaper and easier to add amenities to an entertainer coach than to start over with a non entertainer coach. I bet that to add that many bunks would require the renovation / relocation of almost every system in the bus, i.e. electrical, plumbing, air conditioning, etc.
    If the perfect bus shows up and it is an XLII, the de-lamination issues may have already been addressed. If not, factor that into your price and get Prevost to review the shell and give you a report on the condition. As stated, there are years that are known problems and are likely fixed and years where there were fewer problems. I would talk to Prevost and some 3rd party Prevost repair centers and get their opinion. Is a problem year that is properly fixed less likely to fail than a year that is reported to have less failures?
    There will never be a bus where the pros / cons ratio is 90/10. You will be lucky to find one that is 60/40. Pick the negatives that you want / can manage and you will be fine.
    Keep us posted. It will be fun to see what you end up with.
    Dec 2019
    Brodheadsville
    322
    Mark has good points. Again, find a coach that has a conversion company still in business. Liberty has sent me every OEM part I needed except for plumbing, that being grey pipe.
    Cheers!
    1995 Liberty XL
