Results 1 to 10 of 10
Thread: Bulbs for Light Panels
    Jun 2021
    Andrew
    60
    Default Bulbs for Light Panels
    I have a dilemma.
    Where do I buy the Bulbs for my Panels throughout Coach?
    Will Needle Nose Plyers with a rubber tip remove the Bulbs or is there a better way?
    Thanks
    Pipeliner Prevost.
    644
    Featherlite in Sanford, FL sells them. They are very proud of the bulbs (Think I paid $15 each last time). Have tried to find them from another source but been unsuccessful. Needless to say, Featherlite is not interested in disclosing their supplier.
    1,048
    Chuck, what did you use to remove the lamp from the socket?
    644
    Rubber hose slipped over bulb, or small needle nose pliers.
    Jun 2021
    Andrew
    60
    Thank you Chuck and Mark. I just fell off the chair at the price $15 each, I can't believe this, incredible! I have been searching in Canada for a Source and I'm striking out. If you guys can think of any other American options for these Lights I would persue them. I have to replace about 50 of these sum guns.
    990
    You have 50 bad bulbs? Are you sure?
    Jun 2021
    Andrew
    60
    Hello Mike,
    Yes I have a high number of the Bulbs out. Not an Electrical failure if that's why you asked. We have several full Panels throughout our Coaches and some not all of the Bulbs are out, so not a full Panel Blackout. Anyone know where to get these things?
    I am having a hard time justifying $15 per Bulb to Featherlite.
    Pipeliner Prevost Rick
    99 Featherlite H345.
    990
    I would move a known good bulb to one of the sockets that is dark to see if the theory is correct.
    644
    Put me on the contact list if anyone finds a source for these bulbs outside of Featherlite.
    Nov 2016
    Parkland County
    8
    I have had an unfortunate short somewhere in the panels and have lost all my back panel lighting. Has anyone had this experience? I have the drawings and have tried every fuse that I can find . Relays all work and the light switches work, lights work as they should. I have a 199 Featherlite Vantare H3-45.
