Anyway, if you haven't used your macerator for awhile, you may find that it spins but doesn't pump. The fix is to put water under pressure through a hose into the pump, turn on the pump and prime it.
Then, turn off the water pressure, take the hose to the dump area, and turn it on.
No need to try to siphon the hose by mouth.
Timing is everything.
