Page 15 of 15 FirstFirst ... 5131415
Results 141 to 144 of 144
Thread: Bus Supports / Stands
  1. #141
    988
    OK I am ready to look under the bus, I was wondering if these are the correct body points to put my support stands. I have 4 of the 22 ton red and blacks from Amazon.
    Front:
    Rear:
    Mike Giboney
    1992 Prevost Country Coach
    #60187
  2. #142
    988
    Here is the dimension of the rear, i was concerned about raising the bus up above ride height, not sure if it worked or how high i could go. I could raise the front and both sides but not the drive direction.
    Mike Giboney
    #60187
  3. #143
    Dec 2021
    Indianoa
    1
    Hi Jon, I just found this posting. Are these stands still available? I have a 1990 XL40
  4. #144
    Any steel fabrication or welding shop should be able to make what you want for not much money. The jack points should be illustrated in the service manual.
  1. Bus Stands 2010
    By James in forum WANT/NEED PARTS?
    Last Post: 01-06-2011, 10:49 PM
  2. Jon's jack stands
    Last Post: 04-28-2008, 05:10 AM
