Andrew,
The faint voltage on the turn signal is a poor ground or, as you suspect, the combining function electronics. There's no way I'd consider a non standard connector. 6 and 7 pin connectors work and if you need to replace one on the road they are easily found. If the vehicle needs seperate brake and turn lights, use a 2 to 3 converter. I've used a 3 to 2 on my coach and 2 to 3 on my Explorer for years. There's a much better choice than running a battery charger. Here's a regulated power system.
https://rvibrake.com/products/towed-...y-charger-plus
