Results 11 to 20 of 21
Thread: Holding Tanks Level Monitors
    Sep 2013
    Frankston
    13
    Hello everyone. I have the Phoenix Monitor System on my 02 Royale. It doesn't record gray and black tank levels - they always show empty. Am wondering if there is a reset on the system or some easy solution that will get the gauges working properly? Thanks in advance for any help.
    Rich Potter
    02 Prevost Royale
    Huntsville
    3,135
    Rich,
    You can try one of the cleaners that is supposed to remove gunk from your sensors and see it that works.
    Rich,
    I assume the freshwater reading is correct. The Royale Phoenix system looks pretty simple. It has tubes placed in the tanks and remotely measures the pressure in the tubes. It's possible that the tubes are simply clogged. If so, it looks like you could blow them out. If blowing them out doesn't work, it's likely the sensor. If the fresh water one is working you could troubleshoot the others by connecting the gray or black tube to the fresh water sensor port and see if the freshwater sensor reads the level in the other tanks. I don't have the instructions, but I would guess you have to start with an empty tank after moving or disconnecting the hose to the sensors.
    Good luck,
    Sep 2014
    The Villages
    41
    The level indicators that use air pressure to determine the level work pretty well. The biggest issue is the air line that goes sin the tank is prone to clogging. Try blowing it out with air. Do not blow air towards the receiver, the part that the air hooks to that determines the actual air pressure, the air pressure that is used to measure the level is only about 1 lb per foot of tank depth. Good Luck
    Mikee
    Sep 2012
    Grafton
    182
    How do you blow them out? Do you have to remove the sensor from the top of the tank? Thanks!
    Dick,
    The Tank Sentury models have an air hose that goes from the bottom of the tank to a sensing device. You can disconnect the hose at the tank or the sensing device to blow it out. Once the hose is reinstalled, the Tank Sentury will need to be calibrated. The method varies with model. The therory of operation is really simple. The sensing device blows air down the tube to allow the fluids to then excerpt pressure up the hose. The hydrostatic pressure is then easily measured by the sensing. The sensing device is connected to the remote monitoring panel.
    Call Glen, Royale Phoenix He built it, the fix is cheap
    Dec 2020
    Goldsboro
    174
    Anyone care to detail installation of Sea level tank monitor and reliability
    George and Joan
    2006 Royale March 2024
    Goldsboro NC
    2022 Ford King Ranch
    May 2009
    Regina, Sask, Canada
    130
    Hi George,
    I installed a Sealevel system this winter and it went well. One thing I did that might be a little different is being my tanks were 28 and 22" tall they call for two sensors each to be installed in series to read the complete tank levels. instead I installed one sensor strip on the bottom of my fresh tank and one strip at the top of my Grey Black tank. So I know when one tank is on its bottom 2/3 (fresh) and when my Grey Black is filling its top 2/3. Initally I was only going to install on one tank as when one empties the other fills fairly equally so didnt see a reason to measure both tanks. ( I normally fill my fresh tank and dump the grey at the same time. Dont normally run on park pressure.) The way I have it installed now does give me accurate measure on when one is dropping and the other is rising so thats why Ive installed it like I did. So far so good. A lot cheaper then repairing the Head Hunter system I had before. And quieter!
    Craig Lenz
    Yellow Grass, Saskatchewan
    1996 Angola XLV #5688
    Apr 2018
    Crossville
    278
    You can find the installation instructions for the different models here:
    SeaLevel
    I've had the system on three different coaches. Never a failure, never anything but rock solid indications.
  1. Changing pressure in main tanks
    By nrhareiner in forum Ah Houston, I think we have a problem...
    Last Post: 03-22-2009, 10:43 AM
  2. Rear view monitors
    By Kenneth Brewer in forum MISCELLANEOUS ITEMS
    Last Post: 02-16-2009, 11:01 PM
  3. Liberty Holding Tank Level Gauge
    Last Post: 02-02-2009, 01:09 PM
  4. Water and Holding Tanks
    Last Post: 11-09-2006, 10:24 PM
  5. Prevost Level Low Level
    Last Post: 02-25-2006, 04:33 PM
