Results 1 to 5 of 5
Thread: Side Ext Light Identification - 99 Vantare H3
    Oct 2020
    Tucson
    41
    Default Side Ext Light Identification - 99 Vantare H3
    Hello All,
    OK, I'm flummoxed on what bayonet bulb (and voltage) that is being used here on Bay 1, 3, and 5? I'm pretty sure it's a BA15D, but I have not my ride around to check voltage. Picture attached. Any ideas?
    Indio
    589
    On my 2001 Marathon (H), I replaced all the side lights with LED bulbs from SuperBright LED.
    A slight grind was necessary to the hole where the bulb fit thru, an easy task with my dremmell.
    Now they're super bright and very low power draw.
    https://www.superbrightleds.com/more...ns/5534/12490/.
    I don't remember the Voltage on that circuit, but the bulbs handle 10-30v.
    962
    My fixtures are yellowed from the Sun over the years along with damaged seals, so I replaced all my fixtures with these:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    Oct 2020
    Tucson
    41
    Quote Originally Posted by Hoffman View Post
    Very Nice - don't really have the lens in front of me to check fit. They are mounted sideways in the fixture.
    BTW - Whoever did the stamped concrete work there did a nice job (in my wheelhouse).
    Quote Originally Posted by PrevostNewbie
    I'm liking this option better because I was looking to replace the seals and it may be less fumbling to do a new fixture with the seal than do a new bulb / custom cut gasket job.
    I will keep you two posted. Thanks for the input!
    I recommend the Maxxima MWL-33 referenced. It works great on the high quality Marathon light assemblies. It is not as wide as the pickup truck cargo lights you have.
    The MWL-33 lights do have a lot of straight out light splash that doesn't make them great for flush mounting near eye level light like many door entry lights.
