Results 1 to 6 of 6
Thread: 24 volt charger for chassis
    Dec 2020
    Goldsboro
    174
    Question 24 volt charger for chassis
    Anyone have a 24 volt chassis battery charger that is a smart one. Reduces the charge as batteries get charged and maintains batteries.
    Anyone have 12 volt maintainer for generator battery?
    George and Joan
    2006 Royale March 2024
    Goldsboro NC
    2022 Ford King Ranch
    964
    These are very popular.
    Mike Giboney
    1992 Prevost Country Coach
    #60187
    U do not want a 24 v charger for your chassis. U want one like Mike posted only, one that charges 2 12 v banks. If u have 1 of your 4 chassis Batts go bad a 24v will roast the other 3 trying to keep voltage up. 2 12s will not do that and won't hide the problem either u will catch the bad apple by getting a batt imbalance early on.
    Apr 2018
    Crossville
    278
    Yep, this works really well.
    964
    Here is how I hookup my Battery Tenders to charge two parallel twelve volt banks in series to get 24 Volts with my current battery tenders. I will be buying a Guest charger soon and connecting it the same way. Anyone rewiring this area of the Bus should see how Gil uses Bus Bars. It's a much cleaner setup.
    Mike Giboney
    #60187
    Nov 2018
    PIEDMONT
    473
    Any downside to using a small fused set of alligator clips on the CHASSIS and HOUSE terminals of the jump-start solenoid in engine bay when parked, and letting the inverters maintain the chassis batteries also? I do realize a shore power loss in that scenario would also deplete chassis batteries along with house batteries, but it is stored here at home so not much of a concern.
    I can't take credit for this idea (it was suggested by Rick May) - however I have done this since Dec 2018 and has seemed to work well.
    Billy & Lisa Gaines
    1996 Marathon XL40
