Joe, do you think it's possible for the accessory air coming in on port 1 is leaking out port 3? That seems to be the only way accessory air can exit port 3 while in drive mode and exit port 1. I am trying to wrap my head around how air can come from port 1 on the front ride height valve and pass thru the air control and exhaust valve. In drive mode air pressure is on port 14 which allows air to flow into port 3 and out of port 2 to the ride height valve.
Air Control and Exhaust Valve (Lower Valve)
Port 1 Accessory Supply
Port 2 open when air on port 12
Port 3 open when air is not on port 12
Front 5 way 3 position air control Valve (Upper Valve)
Port 1 pressure Supplied from Port 2 valve below
Port 3 from front ride height valve
Port 5 plugged
Port 14 from Drive Norgren Prevost switch in Drive mode
Port 12 from front Control Norgren
Port 4 Plugged
Port 2 to air bags
