If it's a slow air leak the spool is shifted partially or the seals are leaking. I just aired up my bus and soaped the ports and no leaks. next i asked someone to push the down button on the Prevost Level low and air came rushing out of that port (port 3) . When you dump air does it rush out of that port like it should? The air supply for that valve is the one above it. It's a spring return single pilot valve. When dumping air, the spool is in the spring shifted position. When you want to manually raise the bus up, the air pilot signal shifts the spool over. This pilot signal comes from the top valve and whtever position you are in at Prevost level low. The prevost level low selector switch will select one of the norgrens in the bank depending on which position. Top in the bank is Air Control & Exhaust, second down is Front Control, Third down, Middle is Drive, 4th down is Rear Right control, Last Valve is Rear left Control.
