Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: ISRI seat info
    Fortunately u have an airbag that has a fitting. There r others that have a crimp on a line that enters at the bottom. U can feel the difference in the constitution of that line it's more rubber than plastic. Proprietary to the seat dont think a standard 1/4 I n line would work.
    Zoom in on the ride height valve and the linkage while its blown apart so everybody can get a look of that too.
    Sep 2008
    836
    Make sure you check the valves on the seat control...after I put the lumbar in mine, the only leak was the actual valves..both leaked.
    Pete & EJ Petree
    Sealy, Texas
    990
    Quote Originally Posted by Pete View Post
    For sure, all connections were tested as well as the bladders. The ride height valve needs to be tested with the seat moving up and down also to make sure you check air on both plungers. I also soaped around the bladder. I pumped up the 2 bladders in the back of the seat and 24 hours later they were still at pressure. Should be good to go.
